UEFI Shell Commmands
acpiview - Display ACPI Table information.
alias - Displays, creates, or deletes UEFI Shell aliases.
attrib - Displays or modifies the attributes of files or directories.
bcfg - Manages the boot and driver options that are stored in NVRAM.
cd - Displays or changes the current directory.
cls - Clears the console output and optionally changes the background
and foreground color.
comp - Compares the contents of two files on a byte-for-byte basis.
connect - Binds a driver to a specific device and starts the driver.
cp - Copies one or more files or directories to another location.
date - Displays and sets the current date for the system.
dblk - Displays one or more blocks from a block device.
devices - Displays the list of devices managed by UEFI drivers.
devtree - Displays the UEFI Driver Model compliant device tree.
dh - Displays the device handles in the UEFI environment.
disconnect - Disconnects one or more drivers from the specified devices.
dmem - Displays the contents of system or device memory.
dmpstore - Manages all UEFI variables.
drivers - Displays the UEFI driver list.
drvcfg - Invokes the driver configuration.
drvdiag - Invokes the Driver Diagnostics Protocol.
echo - Controls script file command echoing or displays a message.
edit - Provides a full screen text editor for ASCII or UCS-2 files.
eficompress - Compresses a file using UEFI Compression Algorithm.
efidecompress - Decompresses a file using UEFI Decompression Algorithm.
else - Identifies the code executed when ‘if’ is FALSE.
endfor - Ends a ‘for’ loop.
endif - Ends the block of a script controlled by an ‘if’ statement.
exit - Exits the UEFI Shell or the current script.
for - Starts a loop based on ‘for’ syntax.
getmtc - Gets the MTC from BootServices and displays it.
goto - Moves around the point of execution in a script.
help - Displays the UEFI Shell command list or verbose command help.
hexedit - Provides a full screen hex editor for files, block devices, or m
emory.
i2cdemo - Read/write data from/into I2cDemo Device memory
if - Executes commands in specified conditions.
ifconfig - Modifies the default IP address of the UEFI IPv4 Network Stack.
load - Loads a UEFI driver into memory.
loadpcirom - Loads a PCI Option ROM.
ls - Lists the contents of a directory or file information.
map - Displays or defines file system mappings.
memmap - Displays the memory map maintained by the UEFI environment.
mkdir - Creates one or more new directories.
mm - Displays or modifies MEM/MMIO/IO/PCI/PCIE address space.
mode - Displays or changes the console output device mode.
mv - Moves one or more files to a destination within or between file
systems.
openinfo - Displays the protocols and agents associated with a handle.
parse - Retrieves a value from a standard format output file.
pause - Pauses a script and waits for an operator to press a key.
pci - Displays PCI device list or PCI function configuration space and
PCIe extended
configuration space.
ping - Ping the target host with an IPv4 stack.
reconnect - Reconnects drivers to the specific device.
reset - Resets the system.
rm - Deletes one or more files or directories.
sermode - Sets serial port attributes.
set - Displays or modifies UEFI Shell environment variables.
setsize - Adjusts the size of a file.
setvar - Displays or modifies a UEFI variable.
sf - Read/write data from/into SPI flash.
shift - Shifts in-script parameter positions.
smbiosview - Displays SMBIOS information.
stall - Stalls the operation for a specified number of microseconds.
time - Displays or sets the current time for the system.
timezone - Displays or sets time zone information.
touch - Updates the filename timestamp with the current system date and
time.
type - Sends the contents of a file to the standard output device.
unload - Unloads a driver image that was already loaded.
ver - Displays UEFI Firmware version information.
vol - Displays or modifies information about a disk volume.
作者:Zhang Yinkui  创建时间:2024-01-02 11:44
最后编辑:Zhang Yinkui  更新时间:2026-03-15 21:50
