Shell: acpiview
2024.05.04
Shell> help acpiview
Display ACPI Table information.
ACPIVIEW [[-?] | [[[[-l] | [-s AcpiTable [-d]]] [-q] [-h]] [-r Spec]]]
  -l - Display list of installed ACPI Tables.
  -s - Display only the specified AcpiTable type and only support single
       invocation option.
         AcpiTable    : The required ACPI Table type.
  -d - Generate a binary file dump of the specified AcpiTable.
  -q - Quiet. Suppress errors and warnings. Disables consistency checks.
  -h - Enable colour highlighting.
  -r - Validate that all required ACPI tables are installed
         Spec  : Specification to validate against.
                 For Arm, the possible values are:
                   0 - Server Base Boot Requirements v1.0
                   1 - Server Base Boot Requirements v1.1
                   2 - Server Base Boot Requirements v1.2
  -? - Show help.
  This program is provided to allow examination of ACPI table values from the
  UEFI Shell.  This can help with investigations, especially at that stage
  where the tables are not enabling an OS to boot.
  The program is not exhaustive, and only encapsulates detailed knowledge of a
  limited number of table types.
  Default behaviour is to display the content of all tables installed.
  'Known' table types (listed in NOTES below) will be parsed and displayed
  with descriptions and field values.  Where appropriate a degree of
  consistency checking is done and errors may be reported in the output.
  Other table types will be displayed as an array of Hexadecimal bytes.
  To facilitate debugging, the -s and -d options can be used to generate a
  binary file image of a table that can be copied elsewhere for investigation
  using tools such as those provided by acpica.org.  This is especially
  relevant for AML type tables like DSDT and SSDT.
NOTES:
  1. The AcpiTable parameter can match any installed table type.
     Tables without specific handling will be displayed as a raw hex dump (or
     dumped to a file if -d is used).
  2. -s option supports to display the specified AcpiTable type that is present
     in the system. For normal type AcpiTable, it would display the data of the
     AcpiTable and AcpiTable header. The following type may contain header type
     other than AcpiTable header. The actual header can refer to the ACPI spec
     6.2
     Extra A. Particular types:
       AEST  - Arm Error Source Table
       APIC  - Multiple APIC Description Table (MADT)
       APMT  - Arm Performance Monitoring Unit Table
       BGRT  - Boot Graphics Resource Table
       DBG2  - Debug Port Table 2
       DSDT  - Differentiated System Description Table
       FACP  - Fixed ACPI Description Table (FADT)
       GTDT  - Generic Timer Description Table
       HMAT  - Heterogeneous Memory Attributes Table
       IORT  - IO Remapping Table
       MCFG  - Memory Mapped Config Space Base Address Description Table
       PPTT  - Processor Properties Topology Table
       RSDP  - Root System Description Pointer
       SLIT  - System Locality Information Table
       SPCR  - Serial Port Console Redirection Table
       SRAT  - System Resource Affinity Table
       SSDT  - Secondary SystemDescription Table
       XSDT  - Extended System Description Table
EXAMPLES:
  * To display a list of the installed table types:
    fs0:\> acpiview -l
  * To parse and display a specific table type:
    fs0:\> acpiview -s GTDT
  * To save a binary dump of the contents of a table to a file
    in the current working directory:
    fs0:\> acpiview -s DSDT -d
  * To display contents of all ACPI tables:
    fs0:\> acpiview
  * To check if all Server Base Boot Requirements (SBBR) v1.2 mandatory
    ACPI tables are installed (Arm only):
    fs0:\> acpiview -r 2
Shell> acpiview -h
 --------------- RSDP Table ---------------
Address  : 0xEAC30018
Length   : 36
00000000 : 52 53 44 20 50 54 52 20 - 6F 52 4B 43 50 20 20 02   RSD PTR oRKCP  .
00000010 : 00 00 00 00 24 00 00 00 - 98 FE C3 EA 00 00 00 00   ....$...........
00000020 : 99 00 00 00                                         ....
Table Checksum : OK
RSDP                                 :
  Signature                          : RSD PTR
  Checksum                           : 0x6F
  Oem ID                             : RKCP
  Revision                           : 2
  RSDT Address                       : 0x0
  Length                             : 36
  XSDT Address                       : 0xEAC3FE98
  Extended Checksum                  : 0x99
  Reserved                           : 0 0 0
 --------------- XSDT Table ---------------
Length   : 108
00000000 : 58 53 44 54 6C 00 00 00 - 01 7D 52 4B 43 50 20 20   XSDTl....}RKCP
00000010 : 52 4B 33 35 38 38 20 20 - 00 00 00 00 20 20 20 20   RK3588  ....
00000020 : 13 00 00 01 98 FB C3 EA - 00 00 00 00 98 FA C3 EA   ................
00000030 : 00 00 00 00 18 FD C3 EA - 00 00 00 00 98 E9 C3 EA   ................
00000040 : 00 00 00 00 18 F8 C3 EA - 00 00 00 00 98 ED C3 EA   ................
00000050 : 00 00 00 00 18 FE C3 EA - 00 00 00 00 18 F0 C3 EA   ................
00000060 : 00 00 00 00 98 FF C3 EA - 00 00 00 00               ............
Table Checksum : OK
XSDT                                 :
  Signature                          : XSDT
  Length                             : 108
  Revision                           : 1
  Checksum                           : 0x7D
  Oem ID                             : RKCP
  Oem Table ID                       : RK3588
  Oem Revision                       : 0x0
  Creator ID                         :
  Creator Revision                   : 0x1000013
  Entry[0] - FACP                    : 0xEAC3FB98
  Entry[1] - DBG2                    : 0xEAC3FA98
  Entry[2] - GTDT                    : 0xEAC3FD18
  Entry[3] - APIC                    : 0xEAC3E998
  Entry[4] - MCFG                    : 0xEAC3F818
  Entry[5] - PPTT                    : 0xEAC3ED98
  Entry[6] - SPCR                    : 0xEAC3FE18
  Entry[7] - SSDT                    : 0xEAC3F018
  Entry[8] - BGRT                    : 0xEAC3FF98
 --------------- FACP Table ---------------
Address  : 0xEAC3FB98
Length   : 276
00000000 : 46 41 43 50 14 01 00 00 - 06 F1 52 4B 43 50 20 20   FACP......RKCP
00000010 : 52 4B 33 35 38 38 20 20 - 00 00 00 00 45 44 4B 32   RK3588  ....EDK2
00000020 : 00 00 00 00 00 00 00 00 - 18 75 C3 EA 00 06 00 00   .........u......
00000030 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000040 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000050 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000060 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000070 : 21 00 10 00 00 00 00 00 - 00 00 00 00 00 00 00 00   !...............
00000080 : 00 01 00 03 00 00 00 00 - 00 00 00 00 18 75 C3 EA   .............u..
00000090 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000A0 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000B0 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000C0 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000D0 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000E0 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000F0 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000100 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000110 : 00 00 00 00                                         ....
Table Checksum : OK
FADT                                 :
  Signature                          : FACP
  Length                             : 276
  Revision                           : 6
  Checksum                           : 0xF1
  Oem ID                             : RKCP
  Oem Revision                       : 0x0
  Creator ID                         : EDK2
  Creator Revision                   : 0x0
  FIRMWARE_CTRL                      : 0x0
  DSDT                               : 0xEAC37518
  Reserved                           : 0
  Preferred_PM_Profile               : 0x6
  SCI_INT                            : 0x0
  SMI_CMD                            : 0x0
  ACPI_ENABLE                        : 0x0
  ACPI_DISABLE                       : 0x0
  S4BIOS_REQ                         : 0x0
  PSTATE_CNT                         : 0x0
  PM1a_EVT_BLK                       : 0x0
  PM1b_EVT_BLK                       : 0x0
  PM1a_CNT_BLK                       : 0x0
  PM1b_CNT_BLK                       : 0x0
  PM2_CNT_BLK                        : 0x0
  PM_TMR_BLK                         : 0x0
  GPE0_BLK                           : 0x0
  GPE1_BLK                           : 0x0
  PM1_EVT_LEN                        : 0x0
  PM1_CNT_LEN                        : 0x0
  PM2_CNT_LEN                        : 0x0
  PM_TMR_LEN                         : 0x0
  GPE0_BLK_LEN                       : 0x0
  GPE1_BLK_LEN                       : 0x0
  GPE1_BASE                          : 0x0
  CST_CNT                            : 0x0
  P_LVL2_LAT                         : 0x0
  P_LVL3_LAT                         : 0x0
  FLUSH_SIZE                         : 0x0
  FLUSH_STRIDE                       : 0x0
  DUTY_OFFSET                        : 0x0
  DUTY_WIDTH                         : 0x0
  DAY_ALRM                           : 0x0
  MON_ALRM                           : 0x0
  CENTURY                            : 0x0
  IAPC_BOOT_ARCH                     : 0x0
  Reserved                           : 0x0
  Flags                              : 0x100021
    WBINVD                           : 1
    WBINVD_FLUSH                     : 0
    PROC_C1                          : 0
    P_LVL2_UP                        : 0
    PWR_BUTTON                       : 0
    SLP_BUTTON                       : 1
    FIX_RTC                          : 0
    RTC_S4                           : 0
    TMR_VAL_EXT                      : 0
    DCK_CAP                          : 0
    RESET_REG_SUP                    : 0
    SEALED_CASE                      : 0
    HEADLESS                         : 0
    CPU_SW_SLP                       : 0
    PCI_EXP_WAK                      : 0
    USE_PLATFORM_CLOCK               : 0
    S4_RTC_STS_VALID                 : 0
    REMOTE_POWER_ON_CAPABLE          : 0
    FORCE_APIC_CLUSTER_MODEL         : 0
    FORCE_APIC_PHYSICAL_DESTINATION_MODE : 0
    HW_REDUCED_ACPI                  : 1
    LOW_POWER_S0_IDLE_CAPABLE        : 0
    Reserved                         : 0
  RESET_REG                          :
    Address Space ID                 : 0x0
    Register Bit Width               : 0x0
    Register Bit Offset              : 0x0
    Access Size                      : 0x0
    Address                          : 0x0
  RESET_VALUE                        : 0x0
  ARM_BOOT_ARCH                      : 0x1
  FADT Minor Version                 : 0x3
  X_FIRMWARE_CTRL                    : 0x0
  X_DSDT                             : 0xEAC37518
  X_PM1a_EVT_BLK                     :
    Access Size                      : 0x0
    Address                          : 0x0
  X_PM1b_EVT_BLK                     :
    Access Size                      : 0x0
    Address                          : 0x0
  X_PM1a_CNT_BLK                     :
    Access Size                      : 0x0
    Address                          : 0x0
  X_PM1b_CNT_BLK                     :
    Access Size                      : 0x0
    Address                          : 0x0
  X_PM2_CNT_BLK                      :
    Access Size                      : 0x0
    Address                          : 0x0
  X_PM_TMR_BLK                       :
    Access Size                      : 0x0
    Address                          : 0x0
  X_GPE0_BLK                         :
    Access Size                      : 0x0
    Address                          : 0x0
  X_GPE1_BLK                         :
    Access Size                      : 0x0
    Address                          : 0x0
  SLEEP_CONTROL_REG                  :
    Access Size                      : 0x0
    Address                          : 0x0
  SLEEP_STATUS_REG                   :
    Access Size                      : 0x0
    Address                          : 0x0
  Hypervisor VendorIdentity          : 0
Summary:
  FADT Version                       : 6.3
 --------------- DSDT Table ---------------
Address  : 0xEAC37518
Length   : 3038
00000000 : 44 53 44 54 DE 0B 00 00 - 02 46 52 4B 43 50 20 20   DSDT.....FRKCP
00000010 : 52 4B 33 35 38 38 20 20 - 02 00 00 00 49 4E 54 4C   RK3588  ....INTL
00000020 : 25 09 20 20 10 49 BB 5F - 53 42 5F 08 50 53 55 42   %.  .I._SB_.PSUB
00000030 : 0D 47 44 59 4C 38 58 32 - 30 32 33 00 5B 82 44 1D   .GDYL8X2023.[.D.
00000040 : 50 4B 47 30 08 5F 48 49 - 44 0D 41 43 50 49 30 30   PKG0._HID.ACPI00
00000050 : 31 30 00 08 5F 55 49 44 - 0A 08 14 09 5F 53 54 41   10.._UID...._STA
00000060 : 00 A4 0A 0F 5B 82 40 0C - 43 4C 55 30 08 5F 48 49   ....[.@.CLU0._HI
00000070 : 44 0D 41 43 50 49 30 30 - 31 30 00 08 5F 55 49 44   D.ACPI0010.._UID
00000080 : 0A 09 14 09 5F 53 54 41 - 00 A4 0A 0F 5B 82 24 43   ...._STA....[.$C
00000090 : 50 55 30 08 5F 48 49 44 - 0D 41 43 50 49 30 30 30   PU0._HID.ACPI000
000000A0 : 37 00 08 5F 55 49 44 00 - 14 09 5F 53 54 41 00 A4   7.._UID..._STA..
000000B0 : 0A 0F 5B 82 24 43 50 55 - 31 08 5F 48 49 44 0D 41   ..[.$CPU1._HID.A
000000C0 : 43 50 49 30 30 30 37 00 - 08 5F 55 49 44 01 14 09   CPI0007.._UID...
000000D0 : 5F 53 54 41 00 A4 0A 0F - 5B 82 25 43 50 55 32 08   _STA....[.%CPU2.
000000E0 : 5F 48 49 44 0D 41 43 50 - 49 30 30 30 37 00 08 5F   _HID.ACPI0007.._
000000F0 : 55 49 44 0A 02 14 09 5F - 53 54 41 00 A4 0A 0F 5B   UID...._STA....[
00000100 : 82 25 43 50 55 33 08 5F - 48 49 44 0D 41 43 50 49   .%CPU3._HID.ACPI
00000110 : 30 30 30 37 00 08 5F 55 - 49 44 0A 03 14 09 5F 53   0007.._UID...._S
00000120 : 54 41 00 A4 0A 0F 5B 82 - 44 07 43 4C 55 31 08 5F   TA....[.D.CLU1._
00000130 : 48 49 44 0D 41 43 50 49 - 30 30 31 30 00 08 5F 55   HID.ACPI0010.._U
00000140 : 49 44 0A 0A 14 09 5F 53 - 54 41 00 A4 0A 0F 5B 82   ID...._STA....[.
00000150 : 25 43 50 55 34 08 5F 48 - 49 44 0D 41 43 50 49 30   %CPU4._HID.ACPI0
00000160 : 30 30 37 00 08 5F 55 49 - 44 0A 04 14 09 5F 53 54   007.._UID...._ST
00000170 : 41 00 A4 0A 0F 5B 82 25 - 43 50 55 35 08 5F 48 49   A....[.%CPU5._HI
00000180 : 44 0D 41 43 50 49 30 30 - 30 37 00 08 5F 55 49 44   D.ACPI0007.._UID
00000190 : 0A 05 14 09 5F 53 54 41 - 00 A4 0A 0F 5B 82 44 07   ...._STA....[.D.
000001A0 : 43 4C 55 32 08 5F 48 49 - 44 0D 41 43 50 49 30 30   CLU2._HID.ACPI00
000001B0 : 31 30 00 08 5F 55 49 44 - 0A 0B 14 09 5F 53 54 41   10.._UID...._STA
000001C0 : 00 A4 0A 0F 5B 82 25 43 - 50 55 36 08 5F 48 49 44   ....[.%CPU6._HID
000001D0 : 0D 41 43 50 49 30 30 30 - 37 00 08 5F 55 49 44 0A   .ACPI0007.._UID.
000001E0 : 06 14 09 5F 53 54 41 00 - A4 0A 0F 5B 82 25 43 50   ..._STA....[.%CP
000001F0 : 55 37 08 5F 48 49 44 0D - 41 43 50 49 30 30 30 37   U7._HID.ACPI0007
00000200 : 00 08 5F 55 49 44 0A 07 - 14 09 5F 53 54 41 00 A4   .._UID...._STA..
00000210 : 0A 0F 5B 82 4F 27 53 44 - 43 33 08 5F 48 49 44 0D   ..[.O'SDC3._HID.
00000220 : 52 4B 43 50 30 44 34 30 - 00 08 5F 55 49 44 0A 03   RKCP0D40.._UID..
00000230 : 08 5F 43 43 41 00 14 2B - 5F 43 52 53 08 08 52 42   ._CCA..+_CRS..RB
00000240 : 55 46 11 1A 0A 17 86 09 - 00 01 00 00 2E FE 00 00   UF..............
00000250 : 01 00 89 06 00 01 01 ED - 00 00 00 79 00 A4 52 42   ...........y..RB
00000260 : 55 46 08 5F 44 53 44 12 - 48 0C 02 11 13 0A 10 14   UF._DSD.H.......
00000270 : D8 FF DA BA 6E 8C 4D 8A - 91 BC 9B BF 4A A3 01 12   ....n.M.....J...
00000280 : 40 0B 08 12 27 02 0D 63 - 6F 6D 70 61 74 69 62 6C   @...'..compatibl
00000290 : 65 00 0D 72 6F 63 6B 63 - 68 69 70 2C 72 6B 33 35   e..rockchip,rk35
000002A0 : 38 38 2D 64 77 63 6D 73 - 68 63 00 12 16 02 0D 6D   88-dwcmshc.....m
000002B0 : 61 78 2D 66 72 65 71 75 - 65 6E 63 79 00 0C 00 C2   ax-frequency....
000002C0 : EB 0B 12 0F 02 0D 62 75 - 73 2D 77 69 64 74 68 00   ......bus-width.
000002D0 : 0A 08 12 0A 02 0D 6E 6F - 2D 73 64 00 01 12 0C 02   ......no-sd.....
000002E0 : 0D 6E 6F 2D 73 64 69 6F - 00 01 12 13 02 0D 6D 6D   .no-sdio......mm
000002F0 : 63 2D 68 73 34 30 30 2D - 31 5F 38 76 00 01 12 1E   c-hs400-1_8v....
00000300 : 02 0D 6D 6D 63 2D 68 73 - 34 30 30 2D 65 6E 68 61   ..mmc-hs400-enha
00000310 : 6E 63 65 64 2D 73 74 72 - 6F 62 65 00 01 12 12 02   nced-strobe.....
00000320 : 0D 6E 6F 6E 2D 72 65 6D - 6F 76 61 62 6C 65 00 01   .non-removable..
00000330 : 5B 80 45 4D 4D 43 00 0C - 34 04 7C FD 0A 04 5B 81   [.EMMC..4.|...[.
00000340 : 0B 45 4D 4D 43 43 50 4C - 4C 45 20 14 41 0F 5F 44   .EMMCCPLLE .A._D
00000350 : 53 4D 0C 08 5F 54 5F 30 - 00 A0 41 0E 93 68 11 13   SM.._T_0..A..h..
00000360 : 0A 10 B0 DD 4A 43 F3 8F - D5 49 A7 24 95 84 4B 79   ....JC...I.$..Ky
00000370 : AD 1F A2 48 0C 01 70 99 - 6A 00 5F 54 5F 30 A0 0A   ...H..p.j._T_0..
00000380 : 93 5F 54 5F 30 00 A4 0A - 03 A1 40 0B A0 4D 0A 93   ._T_0.....@..M..
00000390 : 5F 54 5F 30 01 70 83 88 - 6B 00 00 60 A0 19 92 95   _T_0.p..k..`....
000003A0 : 60 0C 00 C2 EB 0B 70 0C - 00 05 00 FF 50 4C 4C 45   `.....p.....PLLE
000003B0 : A4 0C 00 C2 EB 0B A0 19 - 92 95 60 0C 80 D1 F0 08   ..........`.....
000003C0 : 70 0C 00 07 00 FF 50 4C - 4C 45 A4 0C 80 D1 F0 08   p.....PLLE......
000003D0 : A0 19 92 95 60 0C 00 E1 - F5 05 70 0C 00 0B 00 FF   ....`.....p.....
000003E0 : 50 4C 4C 45 A4 0C 00 E1 - F5 05 A0 19 92 95 60 0C   PLLE..........`.
000003F0 : 80 F0 FA 02 70 0C 00 17 - 00 FF 50 4C 4C 45 A4 0C   ....p.....PLLE..
00000400 : 80 F0 FA 02 A0 19 92 95 - 60 0C 00 36 6E 01 70 0C   ........`..6n.p.
00000410 : 00 80 00 FF 50 4C 4C 45 - A4 0C 00 36 6E 01 A0 19   ....PLLE...6n...
00000420 : 92 95 60 0C D8 B8 05 00 - 70 0C 00 BF 00 FF 50 4C   ..`.....p.....PL
00000430 : 4C 45 A4 0C D8 B8 05 00 - A4 00 A5 A4 00 14 3C 53   LE............<S
00000440 : 43 4C 4B 09 A0 13 92 94 - 68 0C 80 1A 06 00 70 0C   CLK.....h.....p.
00000450 : 00 BF 00 FF 50 4C 4C 45 - A1 21 A0 13 92 94 68 0C   ....PLLE.!....h.
00000460 : 80 F0 FA 02 70 0C 00 80 - 00 FF 50 4C 4C 45 A1 0B   ....p.....PLLE..
00000470 : 70 0C 00 06 00 FF 50 4C - 4C 45 5B 82 17 53 44 4D   p.....PLLE[..SDM
00000480 : 4D 14 08 5F 41 44 52 00 - A4 00 14 08 5F 52 4D 56   M.._ADR....._RMV
00000490 : 00 A4 00 5B 82 4F 06 53 - 44 48 43 08 5F 48 49 44   ...[.O.SDHC._HID
000004A0 : 0D 52 4B 43 50 46 45 32 - 43 00 08 5F 55 49 44 01   .RKCPFE2C.._UID.
000004B0 : 08 5F 43 43 41 00 08 5F - 53 31 44 01 08 5F 53 32   ._CCA.._S1D.._S2
000004C0 : 44 01 08 5F 53 33 44 01 - 08 5F 53 34 44 01 14 09   D.._S3D.._S4D...
000004D0 : 5F 53 54 41 00 A4 0A 0F - 14 2B 5F 43 52 53 08 08   _STA.....+_CRS..
000004E0 : 52 42 55 46 11 1A 0A 17 - 86 09 00 01 00 00 2C FE   RBUF..........,.
000004F0 : 00 40 00 00 89 06 00 01 - 01 EB 00 00 00 79 00 A4   .@...........y..
00000500 : 52 42 55 46 5B 82 42 09 - 47 50 49 30 08 5F 48 49   RBUF[.B.GPI0._HI
00000510 : 44 0D 50 52 50 30 30 30 - 31 00 08 5F 55 49 44 00   D.PRP0001.._UID.
00000520 : 08 5F 44 53 44 12 3C 02 - 11 13 0A 10 14 D8 FF DA   ._DSD.<.........
00000530 : BA 6E 8C 4D 8A 91 BC 9B - BF 4A A3 01 12 25 01 12   .n.M.....J...%..
00000540 : 22 02 0D 63 6F 6D 70 61 - 74 69 62 6C 65 00 0D 72   "..compatible..r
00000550 : 6F 63 6B 63 68 69 70 2C - 67 70 69 6F 2D 62 61 6E   ockchip,gpio-ban
00000560 : 6B 00 14 2B 5F 43 52 53 - 00 08 52 42 55 46 11 1A   k..+_CRS..RBUF..
00000570 : 0A 17 86 09 00 01 00 00 - 8A FD 00 01 00 00 89 06   ................
00000580 : 00 09 01 35 01 00 00 79 - 00 A4 52 42 55 46 14 09   ...5...y..RBUF..
00000590 : 5F 53 54 41 00 A4 0A 0F - 5B 82 42 09 47 50 49 31   _STA....[.B.GPI1
000005A0 : 08 5F 48 49 44 0D 50 52 - 50 30 30 30 31 00 08 5F   ._HID.PRP0001.._
000005B0 : 55 49 44 01 08 5F 44 53 - 44 12 3C 02 11 13 0A 10   UID.._DSD.<.....
000005C0 : 14 D8 FF DA BA 6E 8C 4D - 8A 91 BC 9B BF 4A A3 01   .....n.M.....J..
000005D0 : 12 25 01 12 22 02 0D 63 - 6F 6D 70 61 74 69 62 6C   .%.."..compatibl
000005E0 : 65 00 0D 72 6F 63 6B 63 - 68 69 70 2C 67 70 69 6F   e..rockchip,gpio
000005F0 : 2D 62 61 6E 6B 00 14 2B - 5F 43 52 53 00 08 52 42   -bank..+_CRS..RB
00000600 : 55 46 11 1A 0A 17 86 09 - 00 01 00 00 C2 FE 00 01   UF..............
00000610 : 00 00 89 06 00 09 01 36 - 01 00 00 79 00 A4 52 42   .......6...y..RB
00000620 : 55 46 14 09 5F 53 54 41 - 00 A4 0A 0F 5B 82 43 09   UF.._STA....[.C.
00000630 : 47 50 49 32 08 5F 48 49 - 44 0D 50 52 50 30 30 30   GPI2._HID.PRP000
00000640 : 31 00 08 5F 55 49 44 0A - 02 08 5F 44 53 44 12 3C   1.._UID..._DSD.<
00000650 : 02 11 13 0A 10 14 D8 FF - DA BA 6E 8C 4D 8A 91 BC   ..........n.M...
00000660 : 9B BF 4A A3 01 12 25 01 - 12 22 02 0D 63 6F 6D 70   ..J...%.."..comp
00000670 : 61 74 69 62 6C 65 00 0D - 72 6F 63 6B 63 68 69 70   atible..rockchip
00000680 : 2C 67 70 69 6F 2D 62 61 - 6E 6B 00 14 2B 5F 43 52   ,gpio-bank..+_CR
00000690 : 53 00 08 52 42 55 46 11 - 1A 0A 17 86 09 00 01 00   S..RBUF.........
000006A0 : 00 C3 FE 00 01 00 00 89 - 06 00 09 01 37 01 00 00   ............7...
000006B0 : 79 00 A4 52 42 55 46 14 - 09 5F 53 54 41 00 A4 0A   y..RBUF.._STA...
000006C0 : 0F 5B 82 43 09 47 50 49 - 33 08 5F 48 49 44 0D 50   .[.C.GPI3._HID.P
000006D0 : 52 50 30 30 30 31 00 08 - 5F 55 49 44 0A 03 08 5F   RP0001.._UID..._
000006E0 : 44 53 44 12 3C 02 11 13 - 0A 10 14 D8 FF DA BA 6E   DSD.<..........n
000006F0 : 8C 4D 8A 91 BC 9B BF 4A - A3 01 12 25 01 12 22 02   .M.....J...%..".
00000700 : 0D 63 6F 6D 70 61 74 69 - 62 6C 65 00 0D 72 6F 63   .compatible..roc
00000710 : 6B 63 68 69 70 2C 67 70 - 69 6F 2D 62 61 6E 6B 00   kchip,gpio-bank.
00000720 : 14 2B 5F 43 52 53 00 08 - 52 42 55 46 11 1A 0A 17   .+_CRS..RBUF....
00000730 : 86 09 00 01 00 00 C4 FE - 00 01 00 00 89 06 00 09   ................
00000740 : 01 38 01 00 00 79 00 A4 - 52 42 55 46 14 09 5F 53   .8...y..RBUF.._S
00000750 : 54 41 00 A4 0A 0F 5B 82 - 43 09 47 50 49 34 08 5F   TA....[.C.GPI4._
00000760 : 48 49 44 0D 50 52 50 30 - 30 30 31 00 08 5F 55 49   HID.PRP0001.._UI
00000770 : 44 0A 04 08 5F 44 53 44 - 12 3C 02 11 13 0A 10 14   D..._DSD.<......
00000780 : D8 FF DA BA 6E 8C 4D 8A - 91 BC 9B BF 4A A3 01 12   ....n.M.....J...
00000790 : 25 01 12 22 02 0D 63 6F - 6D 70 61 74 69 62 6C 65   %.."..compatible
000007A0 : 00 0D 72 6F 63 6B 63 68 - 69 70 2C 67 70 69 6F 2D   ..rockchip,gpio-
000007B0 : 62 61 6E 6B 00 14 2B 5F - 43 52 53 00 08 52 42 55   bank..+_CRS..RBU
000007C0 : 46 11 1A 0A 17 86 09 00 - 01 00 00 C5 FE 00 01 00   F...............
000007D0 : 00 89 06 00 09 01 39 01 - 00 00 79 00 A4 52 42 55   ......9...y..RBU
000007E0 : 46 14 09 5F 53 54 41 00 - A4 0A 0F 5B 82 40 09 50   F.._STA....[.@.P
000007F0 : 49 4E 43 08 5F 48 49 44 - 0D 50 52 50 30 30 30 31   INC._HID.PRP0001
00000800 : 00 08 5F 55 49 44 0A 04 - 08 5F 44 53 44 12 42 04   .._UID..._DSD.B.
00000810 : 02 11 13 0A 10 14 D8 FF - DA BA 6E 8C 4D 8A 91 BC   ..........n.M...
00000820 : 9B BF 4A A3 01 12 2A 01 - 12 27 02 0D 63 6F 6D 70   ..J...*..'..comp
00000830 : 61 74 69 62 6C 65 00 0D - 72 6F 63 6B 63 68 69 70   atible..rockchip
00000840 : 2C 72 6B 33 35 38 38 2D - 70 69 6E 63 74 72 6C 00   ,rk3588-pinctrl.
00000850 : 14 22 5F 43 52 53 00 08 - 52 42 55 46 11 11 0A 0E   ."_CRS..RBUF....
00000860 : 86 09 00 01 00 00 5F FD - 00 00 01 00 79 00 A4 52   ......_.....y..R
00000870 : 42 55 46 14 09 5F 53 54 - 41 00 A4 0A 0F 5B 82 42   BUF.._STA....[.B
00000880 : 14 49 32 43 32 08 5F 48 - 49 44 0D 50 52 50 30 30   .I2C2._HID.PRP00
00000890 : 30 31 00 08 5F 55 49 44 - 0A 02 08 5F 43 43 41 00   01.._UID..._CCA.
000008A0 : 14 2B 5F 43 52 53 08 08 - 52 42 55 46 11 1A 0A 17   .+_CRS..RBUF....
000008B0 : 86 09 00 01 00 00 AA FE - 00 10 00 00 89 06 00 01   ................
000008C0 : 01 5F 01 00 00 79 00 A4 - 52 42 55 46 08 5F 44 53   ._...y..RBUF._DS
000008D0 : 44 12 4A 07 02 11 13 0A - 10 14 D8 FF DA BA 6E 8C   D.J...........n.
000008E0 : 4D 8A 91 BC 9B BF 4A A3 - 01 12 42 06 04 12 15 02   M.....J...B.....
000008F0 : 0D 69 32 63 2C 63 6C 6B - 2D 72 61 74 65 00 0C 80   .i2c,clk-rate...
00000900 : 3D CD 0B 12 23 02 0D 63 - 6F 6D 70 61 74 69 62 6C   =...#..compatibl
00000910 : 65 00 0D 72 6F 63 6B 63 - 68 69 70 2C 72 6B 33 33   e..rockchip,rk33
00000920 : 39 39 2D 69 32 63 00 12 - 13 02 0D 23 61 64 64 72   99-i2c.....#addr
00000930 : 65 73 73 2D 63 65 6C 6C - 73 00 01 12 10 02 0D 23   ess-cells......#
00000940 : 73 69 7A 65 2D 63 65 6C - 6C 73 00 00 5B 80 49 32   size-cells..[.I2
00000950 : 50 43 00 0C 28 08 7C FD - 0A 04 5B 81 0B 49 32 50   PC..(.|...[..I2P
00000960 : 43 53 43 47 31 30 20 5B - 80 49 32 53 43 00 0C 2C   CSCG10 [.I2SC..,
00000970 : 08 7C FD 0A 04 5B 81 0B - 49 32 53 43 53 43 47 31   .|...[..I2SCSCG1
00000980 : 31 20 14 1A 5F 50 53 33 - 00 70 0C 00 02 00 02 43   1 .._PS3.p.....C
00000990 : 47 31 30 70 0C 02 00 02 - 00 43 47 31 31 14 1A 5F   G10p.....CG11.._
000009A0 : 50 53 30 00 70 0C 00 00 - 00 02 43 47 31 30 70 0C   PS0.p.....CG10p.
000009B0 : 00 00 02 00 43 47 31 31 - 14 08 5F 50 53 43 00 A4   ....CG11.._PSC..
000009C0 : 01 5B 82 42 0A 43 4F 4D - 32 08 5F 48 49 44 0D 41   .[.B.COM2._HID.A
000009D0 : 52 4D 48 30 30 31 31 00 - 08 5F 55 49 44 0A 02 08   RMH0011.._UID...
000009E0 : 5F 43 52 53 11 1A 0A 17 - 86 09 00 01 00 00 B5 FE   _CRS............
000009F0 : 00 10 00 00 89 06 00 01 - 01 6D 01 00 00 79 00 08   .........m...y..
00000A00 : 5F 44 53 44 12 46 05 02 - 11 13 0A 10 14 D8 FF DA   _DSD.F..........
00000A10 : BA 6E 8C 4D 8A 91 BC 9B - BF 4A A3 01 12 3E 03 12   .n.M.....J...>..
00000A20 : 0F 02 0D 72 65 67 2D 73 - 68 69 66 74 00 0A 02 12   ...reg-shift....
00000A30 : 12 02 0D 72 65 67 2D 69 - 6F 2D 77 69 64 74 68 00   ...reg-io-width.
00000A40 : 0A 04 12 18 02 0D 63 6C - 6F 63 6B 2D 66 72 65 71   ......clock-freq
00000A50 : 75 65 6E 63 79 00 0C 00 - 36 6E 01 14 09 5F 53 54   uency...6n..._ST
00000A60 : 41 00 A4 0A 0F 5B 82 4C - 04 58 48 43 30 08 5F 48   A....[.L.XHC0._H
00000A70 : 49 44 0D 50 4E 50 30 44 - 31 30 00 08 5F 55 49 44   ID.PNP0D10.._UID
00000A80 : 00 08 5F 43 43 41 00 14 - 2B 5F 43 52 53 08 08 52   .._CCA..+_CRS..R
00000A90 : 42 55 46 11 1A 0A 17 86 - 09 00 01 00 00 00 FC 00   BUF.............
00000AA0 : 00 40 00 89 06 00 01 01 - FC 00 00 00 79 00 A4 52   .@..........y..R
00000AB0 : 42 55 46 5B 82 4C 04 58 - 48 43 31 08 5F 48 49 44   BUF[.L.XHC1._HID
00000AC0 : 0D 50 4E 50 30 44 31 30 - 00 08 5F 55 49 44 01 08   .PNP0D10.._UID..
00000AD0 : 5F 43 43 41 00 14 2B 5F - 43 52 53 08 08 52 42 55   _CCA..+_CRS..RBU
00000AE0 : 46 11 1A 0A 17 86 09 00 - 01 00 00 40 FC 00 00 40   F..........@...@
00000AF0 : 00 89 06 00 01 01 FD 00 - 00 00 79 00 A4 52 42 55   ..........y..RBU
00000B00 : 46 5B 82 4D 04 58 48 43 - 32 08 5F 48 49 44 0D 50   F[.M.XHC2._HID.P
00000B10 : 4E 50 30 44 31 30 00 08 - 5F 55 49 44 0A 02 08 5F   NP0D10.._UID..._
00000B20 : 43 43 41 00 14 2B 5F 43 - 52 53 08 08 52 42 55 46   CCA..+_CRS..RBUF
00000B30 : 11 1A 0A 17 86 09 00 01 - 00 00 D0 FC 00 00 40 00   ..............@.
00000B40 : 89 06 00 01 01 FE 00 00 - 00 79 00 A4 52 42 55 46   .........y..RBUF
00000B50 : 5B 82 4C 08 47 45 57 55 - 08 5F 48 49 44 0D 47 45   [.L.GEWU._HID.GE
00000B60 : 57 55 32 30 32 33 00 08 - 5F 55 49 44 00 08 5F 41   WU2023.._UID.._A
00000B70 : 44 52 00 14 40 06 5F 43 - 52 53 00 08 52 42 55 46   DR..@._CRS..RBUF
00000B80 : 11 4E 04 0A 4A 8C 21 00 - 01 01 01 00 00 00 01 00   .N..J.!.........
00000B90 : 00 00 00 17 00 00 19 00 - 23 00 01 00 0D 00 5C 5F   ........#.....\_
00000BA0 : 53 42 2E 47 50 49 34 00 - 01 8C 21 00 01 01 01 00   SB.GPI4...!.....
00000BB0 : 00 00 01 00 00 00 00 17 - 00 00 19 00 23 00 01 00   ............#...
00000BC0 : 18 00 5C 5F 53 42 2E 47 - 50 49 30 00 01 79 00 A4   ..\_SB.GPI0..y..
00000BD0 : 52 42 55 46 14 09 5F 53 - 54 41 00 A4 0A 0F         RBUF.._STA....
Table Checksum : OK
ACPI Table Header                    :
  Signature                          : DSDT
  Length                             : 3038
  Revision                           : 2
  Checksum                           : 0x46
  Oem ID                             : RKCP
  Oem Revision                       : 0x2
  Creator ID                         : INTL
  Creator Revision                   : 0x20200925
 --------------- DBG2 Table ---------------
Address  : 0xEAC3FA98
Length   : 92
00000000 : 44 42 47 32 5C 00 00 00 - 00 A4 52 4B 43 50 20 20   DBG2\.....RKCP
00000020 : 00 00 00 00 2C 00 00 00 - 01 00 00 00 00 30 00 01   ....,........0..
00000030 : 0A 00 26 00 00 00 00 00 - 00 80 12 00 00 00 16 00   ..&.............
00000040 : 22 00 00 20 00 03 00 00 - B5 FE 00 00 00 00 00 10   ".. ............
00000050 : 00 00 5C 5F 53 42 2E 55 - 41 52 32 00               ..\_SB.UAR2.
Table Checksum : OK
DBG2                                 :
  Signature                          : DBG2
  Length                             : 92
  Revision                           : 0
  Checksum                           : 0xA4
  Oem ID                             : RKCP
  Oem Revision                       : 0x0
  Creator ID                         : EDK2
  OffsetDbgDeviceInfo                : 0x2C
  NumberDbgDeviceInfo                : 1
  Debug Device Info                  :
    Revision                         : 0x0
    Length                           : 48
    Generic Address Registers Count  : 0x1
    NameSpace String Length          : 10
    NameSpace String Offset          : 0x26
    OEM Data Length                  : 0
    OEM Data Offset                  : 0x0
    Port Type                        : 0x8000
    Port SubType                     : 0x12
    Reserved                         : 0
    Base Address Register Offset     : 0x16
    Address Size Offset              : 0x22
    BaseAddressRegister              :
      Register Bit Width             : 0x20
      Access Size                    : 0x3
      Address                        : 0xFEB50000
    Address Size                     : 0x1000
    NameSpace String                 : \_SB.UAR2
 --------------- GTDT Table ---------------
Address  : 0xEAC3FD18
Length   : 96
00000000 : 47 54 44 54 60 00 00 00 - 02 D8 52 4B 43 50 20 20   GTDT`.....RKCP
00000020 : 00 00 00 00 FF FF FF FF - FF FF FF FF 00 00 00 00   ................
00000030 : 1D 00 00 00 02 00 00 00 - 1E 00 00 00 02 00 00 00   ................
00000040 : 1B 00 00 00 02 00 00 00 - 1A 00 00 00 02 00 00 00   ................
00000050 : FF FF FF FF FF FF FF FF - 00 00 00 00 00 00 00 00   ................
Table Checksum : OK
GTDT                                 :
  Signature                          : GTDT
  Length                             : 96
  Revision                           : 2
  Checksum                           : 0xD8
  Oem ID                             : RKCP
  Oem Revision                       : 0x0
  Creator ID                         : EDK2
  CntControlBase Physical Address    : 0xFFFFFFFFFFFFFFFF
  Reserved                           : 0x0
  Secure EL1 timer GSIV              : 0x1D
  Secure EL1 timer FLAGS             : 0x2
  Non-Secure EL1 timer GSIV          : 0x1E
  Non-Secure EL1 timer FLAGS         : 0x2
  Virtual timer GSIV                 : 0x1B
  Virtual timer FLAGS                : 0x2
  Non-Secure EL2 timer GSIV          : 0x1A
  Non-Secure EL2 timer FLAGS         : 0x2
  CntReadBase Physical address       : 0xFFFFFFFFFFFFFFFF
  Platform Timer Count               : 0
  Platform Timer Offset              : 0x0
 --------------- APIC Table ---------------
Address  : 0xEAC3E998
Length   : 724
00000000 : 41 50 49 43 D4 02 00 00 - 04 29 52 4B 43 50 20 20   APIC.....)RKCP
00000020 : 00 00 00 00 00 00 00 00 - 00 00 00 00 0B 50 00 00   .............P..
00000030 : 00 00 00 00 00 00 00 00 - 01 00 00 00 00 00 00 00   ................
00000040 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000060 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000070 : 00 00 00 00 00 00 00 00 - 00 00 00 00 0B 50 00 00   .............P..
00000080 : 00 00 00 00 01 00 00 00 - 01 00 00 00 00 00 00 00   ................
00000090 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000B0 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
000000C0 : 00 01 00 00 00 00 00 00 - 00 00 00 00 0B 50 00 00   .............P..
000000D0 : 00 00 00 00 02 00 00 00 - 01 00 00 00 00 00 00 00   ................
000000E0 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000100 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000110 : 00 02 00 00 00 00 00 00 - 00 00 00 00 0B 50 00 00   .............P..
00000120 : 00 00 00 00 03 00 00 00 - 01 00 00 00 00 00 00 00   ................
00000130 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000140 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000150 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000160 : 00 03 00 00 00 00 00 00 - 00 00 00 00 0B 50 00 00   .............P..
00000170 : 00 00 00 00 04 00 00 00 - 01 00 00 00 00 00 00 00   ................
00000180 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000190 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000001A0 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
000001B0 : 00 04 00 00 00 00 00 00 - 01 00 00 00 0B 50 00 00   .............P..
000001C0 : 00 00 00 00 05 00 00 00 - 01 00 00 00 00 00 00 00   ................
000001D0 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000001E0 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
000001F0 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000200 : 00 05 00 00 00 00 00 00 - 01 00 00 00 0B 50 00 00   .............P..
00000210 : 00 00 00 00 06 00 00 00 - 01 00 00 00 00 00 00 00   ................
00000220 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000230 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000240 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000250 : 00 06 00 00 00 00 00 00 - 01 00 00 00 0B 50 00 00   .............P..
00000260 : 00 00 00 00 07 00 00 00 - 01 00 00 00 00 00 00 00   ................
00000270 : 17 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000280 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000290 : 00 00 00 00 19 00 00 00 - 00 00 00 00 00 00 00 00   ................
000002A0 : 00 07 00 00 00 00 00 00 - 01 00 00 00 0C 18 00 00   ................
000002B0 : 00 00 00 00 00 00 60 FE - 00 00 00 00 00 00 00 00   ......`.........
000002C0 : 03 00 00 00 0E 10 00 00 - 00 00 68 FE 00 00 00 00   ..........h.....
000002D0 : 00 00 10 00                                         ....
Table Checksum : OK
MADT                                 :
  Signature                          : APIC
  Length                             : 724
  Revision                           : 4
  Checksum                           : 0x29
  Oem ID                             : RKCP
  Oem Revision                       : 0x0
  Creator ID                         : EDK2
  Local Interrupt Controller Address : 0x0
  Flags                              : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    CPU Interface Number             : 0x0
    ACPI Processor UID               : 0x0
    Flags                            : 0x1
    Parking Protocol Version         : 0x0
    Performance Interrupt GSIV       : 0x17
    Parked Address                   : 0x0
    Physical Base Address            : 0x0
    GICV                             : 0x0
    GICH                             : 0x0
    VGIC Maintenance interrupt       : 0x19
    GICR Base Address                : 0x0
    MPIDR                            : 0x0
    Processor Power Efficiency Class : 0x0
    Reserved                         : 0x0
    SPE overflow Interrupt           : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    ACPI Processor UID               : 0x1
    Flags                            : 0x1
    GICV                             : 0x0
    GICH                             : 0x0
    MPIDR                            : 0x100
    Reserved                         : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    ACPI Processor UID               : 0x2
    Flags                            : 0x1
    GICV                             : 0x0
    GICH                             : 0x0
    MPIDR                            : 0x200
    Reserved                         : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    ACPI Processor UID               : 0x3
    Flags                            : 0x1
    GICV                             : 0x0
    GICH                             : 0x0
    MPIDR                            : 0x300
    Reserved                         : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    ACPI Processor UID               : 0x4
    Flags                            : 0x1
    GICV                             : 0x0
    GICH                             : 0x0
    MPIDR                            : 0x400
    Processor Power Efficiency Class : 0x1
    Reserved                         : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    ACPI Processor UID               : 0x5
    Flags                            : 0x1
    GICV                             : 0x0
    GICH                             : 0x0
    MPIDR                            : 0x500
    Reserved                         : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    ACPI Processor UID               : 0x6
    Flags                            : 0x1
    GICV                             : 0x0
    GICH                             : 0x0
    MPIDR                            : 0x600
    Reserved                         : 0x0
  GICC                               :
    Type                             : 0xB
    Length                           : 80
    Reserved                         : 0x0
    ACPI Processor UID               : 0x7
    Flags                            : 0x1
    GICV                             : 0x0
    GICH                             : 0x0
    MPIDR                            : 0x700
    Reserved                         : 0x0
  GICD                               :
    Type                             : 0xC
    Length                           : 24
    Reserved                         : 0x0
    GIC ID                           : 0x0
    Physical Base Address            : 0xFE600000
    System Vector Base               : 0x0
    GIC Version                      : 3
    Reserved                         : 0 0 0
  GICR                               :
    Type                             : 0xE
    Length                           : 16
    Reserved                         : 0x0
    Discovery Range Base Address     : 0xFE680000
    Discovery Range Length           : 0x100000
 --------------- MCFG Table ---------------
Address  : 0xEAC3F818
Length   : 124
00000000 : 4D 43 46 47 7C 00 00 00 - 01 79 52 4B 43 50 20 20   MCFG|....yRKCP
00000020 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
00000030 : 09 00 00 00 00 00 01 01 - 00 00 00 00 00 80 00 40   ...............@
00000040 : 09 00 00 00 01 00 01 01 - 00 00 00 00 00 80 00 80   ................
00000050 : 09 00 00 00 02 00 01 01 - 00 00 00 00 00 80 00 C0   ................
00000060 : 09 00 00 00 03 00 01 01 - 00 00 00 00 00 80 00 00   ................
00000070 : 0A 00 00 00 04 00 01 01 - 00 00 00 00               ............
Table Checksum : OK
MCFG                                 :
  Signature                          : MCFG
  Length                             : 124
  Revision                           : 1
  Checksum                           : 0x79
  Oem ID                             : RKCP
  Oem Revision                       : 0x0
  Creator ID                         : EDK2
  Reserved                           : 0x0
  PCI Configuration Space            :
    Base Address                     : 0x900000000
    PCI Segment Group No.            : 0x0
    Start Bus No.                    : 0x1
    End Bus No.                      : 0x1
    Reserved                         : 0x0
    Base Address                     : 0x940008000
    PCI Segment Group No.            : 0x1
    Start Bus No.                    : 0x1
    End Bus No.                      : 0x1
    Reserved                         : 0x0
    Base Address                     : 0x980008000
    PCI Segment Group No.            : 0x2
    Start Bus No.                    : 0x1
    End Bus No.                      : 0x1
    Reserved                         : 0x0
    Base Address                     : 0x9C0008000
    PCI Segment Group No.            : 0x3
    Start Bus No.                    : 0x1
    End Bus No.                      : 0x1
    Reserved                         : 0x0
    Base Address                     : 0xA00008000
    PCI Segment Group No.            : 0x4
    Start Bus No.                    : 0x1
    End Bus No.                      : 0x1
    Reserved                         : 0x0
 --------------- PPTT Table ---------------
Address  : 0xEAC3ED98
Length   : 544
00000000 : 50 50 54 54 20 02 00 00 - 01 05 52 4B 43 50 20 20   PPTT .....RKCP
00000020 : 00 00 00 00 00 18 00 00 - 03 00 00 00 00 00 00 00   ................
00000030 : 08 00 00 00 01 00 00 00 - 78 01 00 00 00 14 00 00   ........x.......
00000040 : 02 00 00 00 24 00 00 00 - 09 00 00 00 00 00 00 00   ....$...........
00000050 : 00 14 00 00 02 00 00 00 - 24 00 00 00 0A 00 00 00   ........$.......
00000060 : 00 00 00 00 00 14 00 00 - 02 00 00 00 24 00 00 00   ............$...
00000070 : 0B 00 00 00 00 00 00 00 - 00 20 00 00 02 00 00 00   ......... ......
00000080 : 3C 00 00 00 00 00 00 00 - 03 00 00 00 90 01 00 00   <...............
00000090 : A8 01 00 00 C0 01 00 00 - 00 20 00 00 02 00 00 00   ......... ......
000000A0 : 3C 00 00 00 01 00 00 00 - 03 00 00 00 90 01 00 00   <...............
000000B0 : A8 01 00 00 C0 01 00 00 - 00 20 00 00 02 00 00 00   ......... ......
000000C0 : 3C 00 00 00 02 00 00 00 - 03 00 00 00 90 01 00 00   <...............
000000D0 : A8 01 00 00 C0 01 00 00 - 00 20 00 00 02 00 00 00   ......... ......
000000E0 : 3C 00 00 00 03 00 00 00 - 03 00 00 00 90 01 00 00   <...............
000000F0 : A8 01 00 00 C0 01 00 00 - 00 20 00 00 02 00 00 00   ......... ......
00000100 : 50 00 00 00 04 00 00 00 - 03 00 00 00 D8 01 00 00   P...............
00000110 : F0 01 00 00 08 02 00 00 - 00 20 00 00 02 00 00 00   ......... ......
00000120 : 50 00 00 00 05 00 00 00 - 03 00 00 00 D8 01 00 00   P...............
00000130 : F0 01 00 00 08 02 00 00 - 00 20 00 00 02 00 00 00   ......... ......
00000140 : 64 00 00 00 06 00 00 00 - 03 00 00 00 D8 01 00 00   d...............
00000150 : F0 01 00 00 08 02 00 00 - 00 20 00 00 02 00 00 00   ......... ......
00000160 : 64 00 00 00 07 00 00 00 - 03 00 00 00 D8 01 00 00   d...............
00000170 : F0 01 00 00 08 02 00 00 - 01 18 00 00 7F 00 00 00   ................
00000180 : 00 00 00 00 00 00 30 00 - 00 10 00 00 0C 0A 40 00   ......0.......@.
00000190 : 01 18 00 00 7F 00 00 00 - C0 01 00 00 00 80 00 00   ................
000001A0 : 80 00 00 00 04 02 40 00 - 01 18 00 00 7F 00 00 00   ......@.........
000001B0 : C0 01 00 00 00 80 00 00 - 80 00 00 00 04 04 40 00   ..............@.
000001C0 : 01 18 00 00 7F 00 00 00 - 00 00 00 00 00 00 02 00   ................
000001D0 : 00 02 00 00 04 0A 40 00 - 01 18 00 00 7F 00 00 00   ......@.........
000001E0 : 08 02 00 00 00 00 01 00 - 00 01 00 00 04 02 40 00   ..............@.
000001F0 : 01 18 00 00 7F 00 00 00 - 08 02 00 00 00 00 01 00   ................
00000200 : 00 01 00 00 04 04 40 00 - 01 18 00 00 7F 00 00 00   ......@.........
00000210 : 00 00 00 00 00 00 08 00 - 00 04 00 00 08 0A 40 00   ..............@.
Table Checksum : OK
PPTT                                 :
  Signature                          : PPTT
  Length                             : 544
  Revision                           : 1
  Checksum                           : 0x5
  Oem ID                             : RKCP
  Oem Revision                       : 0x0
  Creator ID                         : EDK2
  * Structure Offset *               : 0x24
  Processor Hierarchy Node Structure :
    Type                             : 0x0
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x3
    Parent                           : 0x0
    ACPI Processor ID                : 0x8
    Number of private resources      : 1
    Private resources [0]            : 0x178
  * Structure Offset *               : 0x3C
    Type                             : 0x0
    Length                           : 20
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x24
    ACPI Processor ID                : 0x9
    Number of private resources      : 0
  * Structure Offset *               : 0x50
    Type                             : 0x0
    Length                           : 20
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x24
    ACPI Processor ID                : 0xA
  * Structure Offset *               : 0x64
    Type                             : 0x0
    Length                           : 20
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x24
    ACPI Processor ID                : 0xB
  * Structure Offset *               : 0x78
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x3C
    ACPI Processor ID                : 0x0
    Number of private resources      : 3
    Private resources [0]            : 0x190
    Private resources [1]            : 0x1A8
    Private resources [2]            : 0x1C0
  * Structure Offset *               : 0x98
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x3C
    ACPI Processor ID                : 0x1
  * Structure Offset *               : 0xB8
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x3C
    ACPI Processor ID                : 0x2
  * Structure Offset *               : 0xD8
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x3C
    ACPI Processor ID                : 0x3
  * Structure Offset *               : 0xF8
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x50
    ACPI Processor ID                : 0x4
    Private resources [0]            : 0x1D8
    Private resources [1]            : 0x1F0
    Private resources [2]            : 0x208
  * Structure Offset *               : 0x118
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x50
    ACPI Processor ID                : 0x5
  * Structure Offset *               : 0x138
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x64
    ACPI Processor ID                : 0x6
  * Structure Offset *               : 0x158
    Type                             : 0x0
    Length                           : 32
    Reserved                         : 0x0
    Flags                            : 0x2
    Parent                           : 0x64
    ACPI Processor ID                : 0x7
  * Structure Offset *               : 0x178
  Cache Type Structure               :
    Type                             : 0x1
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x7F
    Next Level of Cache              : 0x0
    Number of sets                   : 4096
    Associativity                    : 12
    Attributes                       : 0xA
    Line size                        : 64
  * Structure Offset *               : 0x190
    Type                             : 0x1
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x7F
    Next Level of Cache              : 0x1C0
    Number of sets                   : 128
    Associativity                    : 4
    Attributes                       : 0x2
    Line size                        : 64
  * Structure Offset *               : 0x1A8
    Type                             : 0x1
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x7F
    Associativity                    : 4
    Attributes                       : 0x4
    Line size                        : 64
  * Structure Offset *               : 0x1C0
    Type                             : 0x1
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x7F
    Number of sets                   : 512
    Associativity                    : 4
    Attributes                       : 0xA
    Line size                        : 64
  * Structure Offset *               : 0x1D8
    Type                             : 0x1
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x7F
    Next Level of Cache              : 0x208
    Number of sets                   : 256
    Associativity                    : 4
    Attributes                       : 0x2
    Line size                        : 64
  * Structure Offset *               : 0x1F0
    Type                             : 0x1
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x7F
    Associativity                    : 4
    Attributes                       : 0x4
    Line size                        : 64
  * Structure Offset *               : 0x208
    Type                             : 0x1
    Length                           : 24
    Reserved                         : 0x0
    Flags                            : 0x7F
    Number of sets                   : 1024
    Associativity                    : 8
    Attributes                       : 0xA
    Line size                        : 64
 --------------- SPCR Table ---------------
Address  : 0xEAC3FE18
Length   : 80
00000000 : 53 50 43 52 50 00 00 00 - 02 EE 52 4B 43 50 20 20   SPCRP.....RKCP
00000020 : 00 00 00 00 12 00 00 00 - 00 20 00 03 00 00 B5 FE   ......... ......
00000030 : 00 00 00 00 08 00 6D 01 - 00 00 00 00 01 00 02 00   ......m.........
00000040 : FF FF FF FF 00 00 00 00 - 00 00 00 00 00 00 00 00   ................
Table Checksum : OK
SPCR                                 :
  Signature                          : SPCR
  Length                             : 80
  Revision                           : 2
  Checksum                           : 0xEE
  Oem ID                             : RKCP
  Oem Revision                       : 0x0
  Creator ID                         : EDK2
  Interface Type                     : 18
  Reserved                           : 0 0 0
  Base Address                       :
    Access Size                      : 0x3
  Interrupt Type                     : 8
  IRQ                                : 0
  Global System Interrupt            : 0x16D
  Baud Rate                          : 0
  Parity                             : 0
  Stop Bits                          : 1
  Flow Control                       : 0x0
  Terminal Type                      : 2
  Reserved                           : 0
  PCI Device ID                      : 0xFFFF
  PCI Vendor ID                      : 0xFFFF
  PCI Bus Number                     : 0x0
  PCI Device Number                  : 0x0
  PCI Function Number                : 0x0
  PCI Flags                          : 0x0
  PCI Segment                        : 0x0
  Reserved                           : 0
 --------------- SSDT Table ---------------
Address  : 0xEAC3F018
Length   : 617
00000000 : 53 53 44 54 69 02 00 00 - 05 15 52 4B 43 50 20 20   SSDTi.....RKCP
00000010 : 50 43 49 45 33 34 4C 30 - 02 00 00 00 49 4E 54 4C   PCIE34L0....INTL
00000020 : 25 09 20 20 10 44 24 5C - 5F 53 42 5F 5B 82 4B 23   %.  .D$\_SB_[.K#
00000030 : 50 43 49 30 08 5F 48 49 - 44 0D 50 4E 50 30 41 30   PCI0._HID.PNP0A0
00000040 : 38 00 08 5F 43 49 44 0D - 50 4E 50 30 41 30 33 00   8.._CID.PNP0A03.
00000050 : 08 5F 43 43 41 00 08 5F - 55 49 44 00 08 5F 53 45   ._CCA.._UID.._SE
00000060 : 47 00 08 5F 42 42 4E 01 - 08 5F 50 52 54 12 30 04   G.._BBN.._PRT.0.
00000070 : 12 0A 04 0B FF FF 00 00 - 0B 24 01 12 0A 04 0B FF   .........$......
00000080 : FF 01 00 0B 24 01 12 0B - 04 0B FF FF 0A 02 00 0B   ....$...........
00000090 : 24 01 12 0B 04 0B FF FF - 0A 03 00 0B 24 01 14 4E   $...........$..N
000000A0 : 09 5F 43 52 53 08 08 52 - 42 55 46 11 4C 08 0A 88   ._CRS..RBUF.L...
000000B0 : 88 0D 00 02 0C 00 00 00 - 01 00 01 00 00 00 01 00   ................
000000C0 : 87 17 00 00 0C 01 00 00 - 00 00 00 00 00 F0 FF FF   ................
000000D0 : FF F0 00 00 00 00 00 00 - 00 01 8A 2B 00 00 0C 01   ...........+....
000000E0 : 00 00 00 00 00 00 00 00 - 00 00 00 10 09 00 00 00   ................
000000F0 : FF FF FE 3F 09 00 00 00 - 00 00 00 00 00 00 00 00   ...?............
00000100 : 00 00 FF 2F 00 00 00 00 - 8A 2B 00 01 0C 03 00 00   .../.....+......
00000110 : 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 FF FF   ................
00000120 : 00 00 00 00 00 00 00 00 - FF 3F 09 00 00 00 00 00   .........?......
00000130 : 01 00 00 00 00 00 79 00 - A4 52 42 55 46 5B 82 4C   ......y..RBUF[.L
00000140 : 07 52 45 53 30 08 5F 48 - 49 44 0D 50 4E 50 30 43   .RES0._HID.PNP0C
00000150 : 30 32 00 08 5F 43 52 53 - 11 42 06 0A 5E 8A 2B 00   02.._CRS.B..^.+.
00000160 : 00 0C 01 00 00 00 00 00 - 00 00 00 00 00 00 00 09   ................
00000170 : 00 00 00 FF FF FF 0F 09 - 00 00 00 00 00 00 00 00   ................
00000180 : 00 00 00 00 00 00 10 00 - 00 00 00 8A 2B 00 00 0C   ............+...
00000190 : 01 00 00 00 00 00 00 00 - 00 00 00 00 40 0A 00 00   ............@...
000001A0 : 00 FF FF 3F 40 0A 00 00 - 00 00 00 00 00 00 00 00   ...?@...........
000001B0 : 00 00 00 40 00 00 00 00 - 00 79 00 08 53 55 50 50   ...@.....y..SUPP
000001C0 : 00 08 43 54 52 4C 00 14 - 41 0A 5F 4F 53 43 04 A0   ..CTRL..A._OSC..
000001D0 : 4A 08 93 68 11 13 0A 10 - 5B 4D DB 33 F7 1F 1C 40   J..h....[M.3...@
000001E0 : 96 57 74 41 C0 3D D7 66 - 8A 6B 00 43 44 57 31 8A   .WtA.=.f.k.CDW1.
000001F0 : 6B 0A 04 43 44 57 32 8A - 6B 0A 08 43 44 57 33 70   k..CDW2.k..CDW3p
00000200 : 43 44 57 32 53 55 50 50 - 70 43 44 57 33 43 54 52   CDW2SUPPpCDW3CTR
00000210 : 4C 7B 43 54 52 4C 0A 1E - 43 54 52 4C 7B 43 54 52   L{CTRL..CTRL{CTR
00000220 : 4C 0A 1D 43 54 52 4C A0 - 10 92 93 69 01 7D 43 44   L..CTRL....i.}CD
00000230 : 57 31 0A 08 43 44 57 31 - A0 16 92 93 43 44 57 33   W1..CDW1....CDW3
00000240 : 43 54 52 4C 7D 43 44 57 - 31 0A 10 43 44 57 31 70   CTRL}CDW1..CDW1p
00000250 : 43 54 52 4C 43 44 57 33 - A4 6B A1 0E 7D 43 44 57   CTRLCDW3.k..}CDW
00000260 : 31 0A 04 43 44 57 31 A4 - 6B                        1..CDW1.k
Table Checksum : OK
ACPI Table Header                    :
  Signature                          : SSDT
  Length                             : 617
  Revision                           : 5
  Checksum                           : 0x15
  Oem ID                             : RKCP
  Oem Table ID                       : PCIE34L0
  Oem Revision                       : 0x2
  Creator ID                         : INTL
 --------------- BGRT Table ---------------
Address  : 0xEAC3FF98
Length   : 56
00000000 : 42 47 52 54 38 00 00 00 - 01 25 49 4E 54 45 4C 20   BGRT8....%INTEL
00000010 : 45 44 4B 32 20 20 20 20 - 02 00 00 00 20 20 20 20   EDK2    ....
00000020 : 13 00 00 01 01 00 00 00 - 18 80 3D EE 00 00 00 00   ..........=.....
00000030 : B8 02 00 00 3C 01 00 00                             ....<...
Table Checksum : OK
BGRT                                 :
  Signature                          : BGRT
  Length                             : 56
  Revision                           : 1
  Checksum                           : 0x25
  Oem ID                             : INTEL
  Oem Table ID                       : EDK2
  Oem Revision                       : 0x2
  Creator ID                         :
  Version                            : 0x1
  Status                             : 0x0
  Image Type                         : 0x0
  Image Address                      : 0xEE3D8018
  Image Offset X                     : 696
  Image Offset Y                     : 316
Table Statistics:
        0 Error(s)
        0 Warning(s)
作者:朱博渊  创建时间:2024-05-04 16:51
最后编辑:朱博渊  更新时间:2025-03-24 17:43
