INITRAMFS是Linux系统启动中的一个关键环节,这一步如果失败,那么就看不见桌面,出现黑屏故障。
格友公众号的文章《抽丝十万米:苦寻黑屏背后的元凶》介绍了一个案例,下面是对应的脚本文件。
`#!/bin/sh
# Default PATH differs between shells, and is not automatically exported
# by klibc dash. Make it consistent.
# Furthermore, this PATH ends up being used by the init, set it to the
# Standard PATH, without /snap/bin as documented in
# https://wiki.ubuntu.com/PATH
# This also matches /etc/environment, but without games path
export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
[ -d /dev ] || mkdir -m 0755 /dev
[ -d /root ] || mkdir -m 0700 /root
[ -d /sys ] || mkdir /sys
[ -d /proc ] || mkdir /proc
[ -d /tmp ] || mkdir /tmp
mkdir -p /var/lock
mount -t sysfs -o nodev,noexec,nosuid sysfs /sys
mount -t proc -o nodev,noexec,nosuid proc /proc
# shellcheck disable=SC2013
for x in $(cat /proc/cmdline); do
case $x in
initramfs.clear)
clear
quiet)
quiet=y
esac
done
if [ "$quiet" != "y" ]; then
quiet=n
echo "Loading, please wait..."
fi
export quiet
# Note that this only becomes /dev on the real filesystem if udev's scripts
# are used; which they will be, but it's worth pointing out
mount -t devtmpfs -o nosuid,mode=0755 udev /dev
# Prepare the /dev directory
[ ! -h /dev/fd ] && ln -s /proc/self/fd /dev/fd
[ ! -h /dev/stdin ] && ln -s /proc/self/fd/0 /dev/stdin
[ ! -h /dev/stdout ] && ln -s /proc/self/fd/1 /dev/stdout
[ ! -h /dev/stderr ] && ln -s /proc/self/fd/2 /dev/stderr
mkdir /dev/pts
mount -t devpts -o noexec,nosuid,gid=5,mode=0620 devpts /dev/pts || true
# Export the dpkg architecture
export DPKG_ARCH=
. /conf/arch.conf
# Set modprobe env
export MODPROBE_OPTIONS="-qb"
# Export relevant variables
export ROOT=
export ROOTDELAY=
export ROOTFLAGS=
export ROOTFSTYPE=
export IP=
export IP6=
export VLAN=
export DEVICE=
export BOOT=
export BOOTIF=
export UBIMTD=
export NETWORK_SKIP_ENSLAVED=
export break=
export init=/sbin/init
export readonly=y
export rootmnt=/root
export debug=
export panic=
export blacklist=
export resume=
export resume_offset=
export noresume=
export drop_caps=
export fastboot=n
export forcefsck=n
export fsckfix=
# mdadm needs hostname to be set. This has to be done before the udev rules are called!
if [ -f "/etc/hostname" ]; then
/bin/hostname -F /etc/hostname >/dev/null 2>&1
fi
# Bring in the main config
. /conf/initramfs.conf
for conf in conf/conf.d/*; do
[ -f "${conf}" ] && . "${conf}"
done
. /scripts/functions
# Parse command line options
case $x in
init=*)
init=${x#init=}
root=*)
ROOT=${x#root=}
if [ -z "${BOOT}" ] && [ "$ROOT" = "/dev/nfs" ]; then
BOOT=nfs
fi
rootflags=*)
ROOTFLAGS="-o ${x#rootflags=}"
rootfstype=*)
ROOTFSTYPE="${x#rootfstype=}"
rootdelay=*)
ROOTDELAY="${x#rootdelay=}"
case ${ROOTDELAY} in
*[![:digit:].]*)
ROOTDELAY=
esac
roottimeout=*)
ROOTDELAY="${x#roottimeout=}"
*[![:digit:].]*)
ROOTDELAY=
esac
loop=*)
# shellcheck disable=SC2034
LOOP="${x#loop=}"
loopflags=*)
LOOPFLAGS="-o ${x#loopflags=}"
loopfstype=*)
LOOPFSTYPE="${x#loopfstype=}"
nfsroot=*)
NFSROOT="${x#nfsroot=}"
initramfs.runsize=*)
RUNSIZE="${x#initramfs.runsize=}"
ip=*)
IP="${x#ip=}"
ip6=*)
IP6="${x#ip6=}"
vlan=*)
VLAN="${x#vlan=}"
boot=*)
BOOT=${x#boot=}
ubi.mtd=*)
UBIMTD=${x#ubi.mtd=}
resume=*)
RESUME="${x#resume=}"
case $RESUME in
UUID=*)
RESUME="/dev/disk/by-uuid/${RESUME#UUID=}"
esac
resume_offset=*)
resume_offset="${x#resume_offset=}"
noresume)
noresume=y
drop_capabilities=*)
drop_caps="-d ${x#drop_capabilities=}"
panic=*)
panic="${x#panic=}"
ro)
readonly=y
rw)
readonly=n
debug)
debug=y
quiet=n
if [ -n "${netconsole}" ]; then
log_output=/dev/kmsg
log_output=/run/initramfs/initramfs.debug
fi
set -x
debug=*)
debug=y
quiet=n
set -x
break=*)
break=${x#break=}
break)
break=premount
blacklist=*)
blacklist=${x#blacklist=}
netconsole=*)
netconsole=${x#netconsole=}
[ "$debug" = "y" ] && log_output=/dev/kmsg
BOOTIF=*)
BOOTIF=${x#BOOTIF=}
hwaddr=*)
BOOTIF=${x#hwaddr=}
fastboot|fsck.mode=skip)
fastboot=y
forcefsck|fsck.mode=force)
forcefsck=y
fsckfix|fsck.repair=yes)
fsckfix=y
fsck.repair=no)
fsckfix=n
esac
done
# Default to BOOT=local if no boot script defined.
if [ -z "${BOOT}" ]; then
BOOT=local
fi
if [ -n "${noresume}" ] || [ "$RESUME" = none ]; then
noresume=y
resume=${RESUME:-}
fi
mount -t tmpfs -o "nodev,noexec,nosuid,size=${RUNSIZE:-10%},mode=0755" tmpfs /run
mkdir -m 0700 /run/initramfs
if [ -n "$log_output" ]; then
exec >"$log_output" 2>&1
unset log_output
fi
maybe_break top
# Don't do log messages here to avoid confusing graphical boots
run_scripts /scripts/init-top
maybe_break modules
[ "$quiet" != "y" ] && log_begin_msg "Loading essential drivers"
[ -n "${netconsole}" ] && /sbin/modprobe netconsole netconsole="${netconsole}"
load_modules
[ "$quiet" != "y" ] && log_end_msg
starttime="$(_uptime)"
starttime=$((starttime + 1)) # round up
export starttime
maybe_break premount
[ "$quiet" != "y" ] && log_begin_msg "Running /scripts/init-premount"
run_scripts /scripts/init-premount
maybe_break mount
log_begin_msg "Mounting root file system"
# Always load local and nfs (since these might be needed for /etc or
# /usr, irrespective of the boot script used to mount the rootfs).
. /scripts/local
. /scripts/nfs
. "/scripts/${BOOT}"
parse_numeric "${ROOT}"
maybe_break mountroot
mount_top
mount_premount
mountroot
log_end_msg
if read_fstab_entry /usr; then
log_begin_msg "Mounting /usr file system"
mountfs /usr
log_end_msg
fi
# Mount cleanup
mount_bottom
nfs_bottom
local_bottom
case "$IP" in
""|none|off)
case "$IP6" in
""|none|off) ;; # Do nothing
configure_networking
esac
esac
maybe_break bottom
[ "$quiet" != "y" ] && log_begin_msg "Running /scripts/init-bottom"
# We expect udev's init-bottom script to move /dev to ${rootmnt}/dev
run_scripts /scripts/init-bottom
# Move /run to the root
mount -n -o move /run ${rootmnt}/run
validate_init() {
run-init -n "${rootmnt}" "${1}"
# Check init is really there
if ! validate_init "$init"; then
echo "Target filesystem doesn't have requested ${init}."
init=
for inittest in /sbin/init /etc/init /bin/init /bin/sh; do
if validate_init "${inittest}"; then
init="$inittest"
break
fi
done
fi
# No init on rootmount
if ! validate_init "${init}" ; then
panic "No init found. Try passing init= bootarg."
fi
maybe_break init
# don't leak too much of env - some init(8) don't clear it
# (keep init, rootmnt, drop_caps)
unset debug
unset MODPROBE_OPTIONS
unset DPKG_ARCH
unset ROOTFLAGS
unset ROOTFSTYPE
unset ROOTDELAY
unset ROOT
unset IP
unset IP6
unset VLAN
unset BOOT
unset BOOTIF
unset DEVICE
unset UBIMTD
unset blacklist
unset break
unset noresume
unset panic
unset quiet
unset readonly
unset resume
unset resume_offset
unset noresume
unset fastboot
unset forcefsck
unset fsckfix
unset starttime
# Move virtual filesystems over to the real filesystem
mount -n -o move /sys ${rootmnt}/sys
mount -n -o move /proc ${rootmnt}/proc
# Chain to real filesystem
# shellcheck disable=SC2086,SC2094
exec run-init ${drop_caps} "${rootmnt}" "${init}" "$@" <"${rootmnt}/dev/console" >"${rootmnt}/dev/console" 2>&1
echo "Something went badly wrong in the initramfs."
panic "Please file a bug on initramfs-tools."
作者:Zhang Yinkui 创建时间:2024-11-15 11:49
最后编辑:Zhang Yinkui 更新时间:2026-03-15 21:50
