nano code 连接Linux调试一直卡在starting session
请教各位大佬:
按教程选择连接选项后,连接GDK上Ubuntu进行调试,nano code 一直卡在starting session,后续无任何反应,在Windows上可以正常调试,具体信息如下:
Starting...
Starting KD session type=usb3,proto=dcid,ipc=open,opt=rxs
nano code 信息如下:
Version: 1.43.0-beta (user setup)
Commit: 173cb094b47727a075ff456ee273004e5fd0c017-20200624
Date: 2020-06-24T03:48:31.042Z
Electron: 7.1.11
Chrome: 78.0.3904.130
Node.js: 12.8.1
V8: 7.8.279.23-electron.0
OS: Windows_NT x64 10.0.18363
NanoCode: 20200624
nano code output info :
12:35:52#ND:NDI got hello from 1.0.3
12:38:46#ND:Found api-ms-win-core-libraryloader-l1-1-0.dll
12:38:46#NB:Setup of extension loader has error 0x1.You may need to set extension search path by executing '.dllpath c:\nanocode\exts' command.
12:38:46#NB:Starting KD session type=usb3,proto=dcid,ipc=open,opt=rxs
12:38:46#JTAG:Failed to load IPC API DLL from C:\IntelSWTools\system_studio_2020\tools\python3\Lib\site-packages\py2ipc\windows\x64\IpcApiAccess_x64.dll gle=126
12:38:46#JTAG:Please assign the right path to the ipcapi item in config file c:\nanocode\data\ndb.cfg.
12:38:46#NB:failed to setup KD proxy for 0x80004005
注册表信息:
计算机\HKEY_LOCAL_MACHINE\SOFTWARE\Intel\DAL
InstallPath: C:\Program Files (x86)\IntelSWTools\sw_dev_tools\tools\DAL_1.2012.1214.110\
